Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we run our Unigine Valley 1.0 benchmark, which is our most GPU limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (2,560 x 1,440).
Nvidia GeForce GTX 750 Ti 2GB
AMD Radeon R7 260X 2GB
Nvidia GeForce GTX 660 2GB
AMD Radeon R9 270 2GB
AMD Radeon R9 270X 2GB
Nvidia GeForce GTX 760 2GB
Nvidia GeForce GTX 770 2GB
AMD Radeon R9 280X 3GB
Nvidia GeForce GTX 780 3GB
Nvidia GeForce GTX Titan 6GB
Nvidia GeForce GTX 780 Ti 3GB
Nvidia GeForce GTX Titan Black 6GB
AMD Radeon R9 290 4GB
AMD Radeon R9 290X 4GB
System Power Draw in Watts (lower is better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark, as its DirectX 11 features will stress all parts of a modern GPU. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (2,560 x 1,440).
20
30
40
50
60
70
80
Delta T in °C (lower is better)
*As we do not have stock samples of the AMD Radeon R9 280X or AMD Radeon R9 270 they are not included in the thermal performance graphs
